C4DtoA 4.8.5.1 Crashes constantly
Kidmograph
Message 1 of 16
Kidmograph
I'm experiencing continuous crashes in both Mac (M4) and PC with latest plugin update for C4D.
The scene isn't complex. Just textures, toon shaders/render, and some non-hi poly meshes..
are there any common issues or it's just me? Do you recommend to roll-back?
Thanks in advance.
-G
Replies (15)
Message 2 of 16
peter_horvath
The latest plugin version is working fine on my workstation. Do you have the same crashes in every scene, or only in a specific one? Do the crashes started to happen after a plugin update? If so, what was the last version that was working?
Can you send me the minidump.dmp file from that _bugreports folder you have in your screenshot (if exists)?
// Peter Horvath
// C4DtoA developer
Message 3 of 16
Kidmograph
Edit: Minidump added
Hi Peter,
Seems to be this project. Tested older and different scenes and it works ok so far.
The issue happens while running the IPR while changing parameters in the shaders (both the old xpresso and the new node system)
I can't attach the minidump (it says the extension .dmp isn't supported), but attached the bug report.txt.
Happy to send the collect, but since it's just this particular file (I was just starting creating that scene just for fun so I will start from scratch at any other time), no worries.
Message 4 of 16
Stephen.Blair
You could just rename the dmp file to minidump.txt
// Stephen Blair
// Arnold Renderer Support
Message 5 of 16
peter_horvath
You can rename to txt as Stephen suggested or add it to a zip file. Unfortunately, I can't do much with the _BugReport.txt file, because it does not have any debug information we need.
If the issue is specific to your scene and it's not confidential, would it be possible to share that scene? Or a minimal version of the scene with replacement meshes and textures, that still show the problem?
// Peter Horvath
// C4DtoA developer
Message 6 of 16
peter_horvath
Sorry, I still can't see the minidump attached to the report.
// Peter Horvath
// C4DtoA developer
Message 7 of 16
Kidmograph
Added it as .zip file
Also added the project file with the assets.
Thanks.
Message 8 of 16
Kidmograph
Hello Peter,
I have uploaded the project file and the mini dump days back..let me know if you had time to look at it.
-G
Message 9 of 16
peter_horvath
Sorry for the late reply. I could get to your issue only today. The good news is that I can reproduce the crash with your scene. I'm not sure yet why it's crashing though, I have to investigate more. Will let you know.
// Peter Horvath
// C4DtoA developer
Message 10 of 16
Kidmograph
Thanks for getting back to me. Ok, that sounds great!
Message 11 of 16
peter_horvath
Can you please try to set 'enable_fast_ipr off' in Render Settings > Diagnostinc > User Options, and see if that fixes the crash?
// Peter Horvath
// C4DtoA developer
Message 12 of 16
Kidmograph
Did that and it's the same.
Keep crashing on simple things such as changing object subdivision or trying to open a shader..
Message 13 of 16
peter_horvath
Good news, we have found what's causing the crash. Sorry, that it took so long. It will be fixed in a next release. In your repro scene, the displacement on the Cube is triggering it, but it's a more generic problem introduced in one of the recent releases.
// Peter Horvath
// C4DtoA developer
Message 14 of 16
Kidmograph
Hey Peter,
Sorry for the delay. I have been playing with the file and got to the same conclusion. I have deactivated the displacement node and it ran ok. In fact I have finished the little scene:
https://www.threads.com/@kidmograph/post/DUCK7Vuj04f?xmt=AQF0_LO1gT2mKZ2782KoEMH1dDDXKYdizaZDGYKcUhk...
Thanks for the quick support, even when we couldn't fix it for now. 👍
Message 15 of 16
peter_horvath
Looking awesome. I'm glad you could finish the project.
// Peter Horvath
// C4DtoA developer
Message 16 of 16
Kidmograph
Thank you man!
