Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Skydome + OSL HDRI and portal lights
8 REPLIES 8
Message 1 of 9
CiroCardoso3v
782 Views, 8 Replies
Ok, I am not sure if this is a bug or not, but here it goes.
Interior scene - Lighting done with Skydome using a OSL HDRI Loader + Portals
This is how the render looks like with Skydome Samples 2 and no Portal Lights
And this is what it looks like with Skydome Samples 5 and with Portal Lights
And this is the Skydome with 20 Samples
Where is the scene:
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Tags (3)
Labels (3)
8 REPLIES 8
Message 2 of 9
Here is the link for the scene
https://we.tl/t-c4t9ObGRgl
Ciro Cardoso
Message 3 of 9
lee_griggs
in reply to: CiroCardoso3v
I see an improvement using these settings:
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 9
CiroCardoso3v
in reply to: lee_griggs
Ok, so in this case the portal lights aren't contributing too much to clean the noise, right? I was expecting a cleaner result between no portal lights and with portal lights. Just wanted to check if I was missing something, or if this could be a potential bug.
Ciro Cardoso
Message 5 of 9
pproestos
In my last project I do right now, I have abbandoned skydome and portals, using only an hdri environment map and imagers. I will post my renders when they're ready.
Message 6 of 9
lee_griggs
Yes, I would still rely on diffuse samples to clean up the extra noise. The portals can only do some much as in the example here.
Lee Griggs
AUTODESK
Message 7 of 9
CiroCardoso3v
in reply to: pproestos
Yes, I am using a HDRI map on the skydome. You still need portal lights.
Ciro Cardoso
Message 8 of 9
CiroCardoso3v
Great. Just wanted to check that. On previous projects, portal lights did help quite a lot, so I was surprise to see little improvement on this one.
Ciro Cardoso
Message 9 of 9
CiroCardoso3v
Also this doesn't have any Noice applied. That will do the magic
Ciro Cardoso
