Arnold for 3ds Max Forum
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Show/hide objects with toon shader
5 REPLIES 5
Markus_StÃ_gner
755 Views, 5 Replies
Hello.
In the past, I used the physical material- cutout map slot with a color convert map to show / hide objects for rendering (in Arnold).
Now I only want to do this with the toon shader.
Is it possible to do that with the toon shader?
So hide in successive frams objects.
I need this for technical documentation (assembly instructions, ..)
What I have to do to implement this? Or is there a better solution?
thank you for your help
Tags (1)
Labels (1)
  • toon
5 REPLIES 5
in reply to: Markus_StÃ_gner
Just animate the mix amount. 😉
Have you also tried adjusting the camera clipping planes?
Lee Griggs
Arnold rendering specialist
AUTODESK
I do not know, where can I find these?
Which settings do I have to make?
thx
Thanks, i think this settings are ok.
