CPU Denoising
CPU Denoising
Benedwilliams
Observer Observer
CPU Denoising
Benedwilliams
Observer
Observer
Within the AOVs manager, I add an RGBa AOV, tick 'Denoise', and try to render. I get an error saying no compatible GPUs found. I'm using a fairly old Nvidia card but thought Arnold Denoiser just uses CPUs?
madsd
If your card is too old you can use the CPU denoiser instead.
The CPU denoiser has an UI section exposed in the Arnold render panel.
You set an output, so first render a file to disk so you can grab the path and inject, after this you can keep rerendering and testing new sweetspots between rendered noise and final denoised quality.
Benedwilliams
Observer
Observer
Thanks.
I think I've got it now. I was mixing up the Optix and Noice controls!
