Alias warning Failed to create directory : errlogs Error 4 : An I/O problem has occurred
sdleesy19
Observer Observer
sdleesy19
Observer
Observer
i installed and uninstalled 2021 ~ 2024 versions but in doesn't have solved
 how can i solved this?
c3systems
It seems like Alias cannot create the folder called errlogs, where the errorlogs are stored.
The default location of the errlogs folder is c:\Users\(your_login)\Documents\Autodesk\Alias\errlogs
If it does not exists, try creating the above folder structure manually. If you do not have the permission to create, please ask the administrator to give necessary permissions for Alias to create the errlogs folder.
Hope it helps.
