Select Previous Button
It would be quite nice to have a button to quickly select all items from the previous selection and add other members.......ie when you have performed say a copy or mirror operation and then realise you have missed a plate or member.
I realise there are many ways of selecting assemblies and marking them and adding to marking, but sometimes it would just be a little quicker if there was a button that would quickly re-select the previous selection.
3 Comments
sorry but this is implemented already. If you use a command and then press "p" for previous, the last selection is used.
In the german version the command is "v" so don't wonder the command in the following video. It's a only a short video with a very simple example, but it's works with every selection.
dave_conibear
..............that's great Sebastian............always good to learn something new............thanks for that
haedicu
Using AutoCAD workflow solves the request.
