Show only
Search instead for
We need an option to oversize holes in one ply in gable end connection-either in beam or in cap plate. Currently we have only the slotted holes option.
I hope I understand your problem. But you could set up the hole size by doubleclick in the screw. The holes could not be changed to another hole, but the hole tolerance could be changed in the first register.
BTW: I only want to help you and if it's better for you I meant "the problem" I really understand, that this is not only your problem. Why do you take it personally everytime? If you will do it, you will reach a point, where no one will give you answers. (in my case, this answer will be the last one)
And in my installation, I could double click on the bolt and could change the tolerance: Gable wall end plate_screw
