Base Plate Slotted hole options
In the base plate macro there is the option to turn on slotted holes, there doesnt seem to be any options to edit the properties of the slots within the joint dialogue, if you double click on the slots you cannot edit anything becuase they are locked by the joint.
6 Kommentare
Marakuja88
Hi Rob,
I have got the same problem, hopefully  someone knows the answer.
KR
Przem
Nicht anwendbar
is there only 3 people that have ran into this?  really
Nicht anwendbar
I have got the same problem here.
The only way to edit de slotted holes, is to delete the grey model view box and to edit de anchors manually by double clicking on it.
sh.yuL6HC4
Same issue to us. We need to control option of base plate joint for column of light beam system.
Nicht anwendbar
I have same problem, but I "solve" it by adding additional slotted holes to plates in master and slave macros. I didn't delete macro.
jalfaroAED24
Same Issue here too I hate having to explode macros when the obvious solution would be to allow the user more freedom in the software. Capture.JPG
Idee einsenden
