I use Advance Steel 2019 French.
I need to set the default Bolt "EN ISO 4017", set: "E2R" and "Hole Tolerance": 2.5.
In "management Tools", "Defaults" I set the default bolt "EN ISO 4017". Works fine.
But the issue: for predefined nuts I set "E2R". It doesn’t work. Every time he creates a bolt, the default is "E".
Same issue for "Hole Tolerance"
Please check the pictures: 1-Defaults.png and 2-Result.png.
Can you make all Defaults configurations work please?
