Propegate joint idea for future versions of AS
The new feature in 2020 is that we can propegate a joint to similar joints. But I think AS should work better with this feature. For example. I have a column and I placed a endplate on top of the column. Now I want to propegate it to all my other columns. But when I do this it also places the endplate on columns that are allready connected. This are things that can be missed in a big project. So AS should see if columns or beams are allready connected and leave them alone. (see also the images included)
Thanks.
1 Kommentar
I vote for it, but maybe to points:
  • The propagate tool is only working for beam, which could be seen. So if you want go get sure, that there's no problem, just select the beams and use the commands for "show selected" or "selected off"
  • what should be done, if I want to place a joint on a beam, where a joint already exist? Maybe I want to add a stiffener to a region, where another joint is existing, so the software is not placing it there because there is already a connection. So the software had to control the type of connection, this will take much time.
Idee einsenden
