Document Manager Highlight Changed files
Most of the time when you do a force update on a file in the document manager you need to go back into that file and replace dimensions that have been deleted or adjust the changes made.
It would be helpful if the text colour of the updated file changed to highlight the files altered. This can be deleted after the file has been opened and saved or switched off manually.
Before Update
After Update
Better after update
When you update many drawings without doing a revision update this would save a lot of time.
Gary
3 Kommentare
iwafb
Nice one!
DM wish list must be getting rather large now...Smiley (zwinkernd)
Austruct
An easier option for the developers would be, if we could at least sort the drawings within the folder by date modified as well as by name. This would allow us temporarily to sort the changed documents, and easily process them through the revision manager.
haedicu
Status geändert in: Future Consideration
Thank you for sharing this idea with us. We will keep it in mind for any future improvement on document management in Advance Steel.
best regards
Udo
Idee einsenden
