Most of the time when you do a force update on a file in the document manager you need to go back into that file and replace dimensions that have been deleted or adjust the changes made.
It would be helpful if the text colour of the updated file changed to highlight the files altered. This can be deleted after the file has been opened and saved or switched off manually.
Before Update
After Update
Better after update
When you update many drawings without doing a revision update this would save a lot of time.
Gary
