Do stop moving of cut view symbols during view update
Please find a way to stop the annoying cut views symbols movement during detail update.
In this case below 11 symbols were first manually moved and during view depth update they moved and some of them over dimension lines.
Ilko Dimitrov
16 Comments
acbsdesign
Per attached screen shot, please prevent moving / updating detail cut views when updating other cut views from same detail.
Similar to movement of labels, compass marks and messing up dimensions, updating a cut view causes mess by moving other cut views.
Once a cut view is manually moved, dimensions and labels adjusted-updating shall be blocked and not initiated by updating other cut views from same detail.
The picture as you can see is messy. Hopefully this will be considered 'an important' improvement and it will find a place in the busy development team schedule.
Ilko Dimitrov
haedicu
Status changed to: Gathering Support
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
cclemmercadman
I find this to be extremely frustrating, as it creates double work or more depending on number of revisions.  Everyone should flag this post.
haedicu
acbsdesign
This is another example how a section view is moved over another view during detail update.
fd-disegni
ME TOOSmiley Sad
acbsdesign
All of us TOO.
acbsdesign
The man with the archives-are the 50 votes enough now?
lukes
this is very frustrating and I am also joining a request for redress.
DumitruBerteanu
While I was reviewing this idea I struggled to reproduce it on a drawing from my side. The views do not move unless the rearrange view command is used on a drawing, and cut symbols have an internal flag that is triggered when the symbol is manually moved, which means that it can have two states:
- automatic (symbol was not moved manually) - it will reevaluate its position and move if needed during update, if it no longer have "room". An example here would be : You have an attached plate (a gusset) that requested a cut. The symbol is placed "above" the gusset. If the gusset size is modified in the model (its size along Y for example is increased), then the symbol will move during update to accommodate the new "above" position, avoiding collision with the element .
- manual (symbol was moved at least once by its grip) - the symbol no longer moves, regardless of what happens around it.
It would be great if you could help me with some examples of those symbols or views moving. It is important to know if this issue appears on shop or GA drawings, manual or automatic cuts, and also the Advance Steel version.
Thank you very much,
Dumitru Berteanu
acbsdesign
Dumitru,
acbsdesign
Mess for a notebook caseMess for a notebook case
@DumitruBerteanu,
Attached please find a screen shot of a messed dwg during update, model is too large to attach here, but basically as you can see also other users are complaining about same issues-symbols moving, and section views regenerating and moving.
Thank you again for looking at this and have a great day.
Ilko Dimitrov, ACBS
acbsdesign
@DumitruBerteanu,
Drawing was created initially last fall before FX2. Dimensions are all messed up.
After XF2 dimensions are more stable, I really appreciate your work making them stable.
The next big thing IMO is to stop default views from regenerating, and moving (!!!) during update.
Please send this screenshot to your product manager for review and comment, he is usually denying any issue that exists in Advance Steel, at least this is what he is reporting to his manager!
I have the contact info of the new CEO of Autodesk, I will probably end up calling him and explain what are the remaining issues with Advance.
I know we may be asking sometimes for many things, but basics are still not covered.
Ignorance is never a good friend of productivity.
Have a great day.
Ilko Dimitrov
ACBS
acbsdesign
@DumitruBerteanu
Hi Dumitru,
I have a model with dwg sample where the section view symbols moved, please send me a link where to upload it.
Thank you.
Ilko Dimitrov,
ACBS
DumitruBerteanu
acbsdesign
@DumitruBerteanu
Great job, so far - not moving in AS2020.
Thank you.
Ilko Dimitrov
ACBS
