Do not label and dimension holes in other flange for beam
Per attached screen pic:
Beam-Top View-holes in bottom flange are labeled and dimesnioned-this is creating unnecessary clean-up-if holes in bottom flange are labeled and
dimensioned once in bottom view, it is not necessary to be labeled and dimensioned again on top view.
Best if they are not shown at all if they are in the other flange, but then probably we have to deal with different clipping for top and bottom view.
Ilko Dimitrov
4 Comments
haedicu
Thank you for the feedback. We will investigate possible solutions and come back to you later.
best regards
Udo
haedicu
Status changed to: Accepted
Thanks for reporting this issue. We will take it in consideration for one of the next Advance Steel releases.
best regards
Udo
haedicu
Advance Steel 2017
acbsdesign
Hi Udo,
Beam dwg style looks mutch better now,
Saving time for cleaning top and bottom view.
Thank you for the cooperation.
Ilko Dimitrov
