MP Quantity in dimension label does not match the real MP quantity
This was subitted to tech. support some 6+/- months ago, hoping the developers will fix it with the UR releases.
Per the attached screen pic:
Dimension label does include MP quantity-MP quantity does not match the real MP quantity.
Numbering was done SP Number=Assembly Number
If instead of %MPQuantity just %Quanity is entered, then the two numbers match.
In other words, if we have 8 beams 1B1, then in dimension label the quantity will be 8, not 1.
Hopefully this will be fixed.
Ilko Dimitrov
5 Kommentare
haedicu
Status geändert in: Accepted
Thank you for submitting this issue. We will fix it for one of our next releases.
best regards
Udo
haedicu
Status geändert in: Future Consideration
while reviewing the AISC examples, i found that one:
http://dts.aisc.org/courses/dts/drawings/13.pdf
However the value in the dimension line looks like the part mark and i haven't found an example, where the quantity is listed in a dimension. So my proposal is to completely remove the quantity from the dimension label. OK?
best regards
Udo
acbsdesign
Hi Udo,
No, it is not OK.
When this feature was presented by your team, it was welcomed, knowing other software  is doing this for years.
What I ask is a developer to change the values in the default Advance DSM, typ for all assemblies for the next release.
It will take him / her  less than an hour
On the other end, if you leave all users to deal with it-they are thousands, the shop personnel is thousands multiplied by at least 10, and add the approvers to let them mark the quantity in red, all this is far more than an hour spent by your team.
As for the AISC sample-I can only guess why is shown this way, but won't comment.
Ilko Dimitrov
acbsdesign
Hi Udo,
Sorry for the confusion, if the quantities are listed within the detail title, then they are not needed in the dimension labels.
Just Name and Length.
Have a great day.
Ilko Dimitrov
haedicu
Status geändert in: Implemented
Thanks Ilko,
we've adjusted this for the next beta.
- no quantity in dimension
- exact quantity in detail title
best regards
Udo
Idee einsenden
