Dimensions running, control Text position above/below line via DSM.
When using Automatic running (Linear absolute type),  if the dimension is below the object body,  then the text is sometime required to be positioned above the line under certain standards,  however this is possible manually via the AS dimension properties, but within the AS Drawing Style Manager, cannot see the same option to set this as a standard request to the Dimension Strategy.
So the Request is to add this option to allow the text to swap sides of the dimension line (Above/Below the line via a check box)
See attached word file explaining further.
3 Comments
acbsdesign
Current Workaround
We do this all the time when we have holes in bottom flanges.
acbsdesign
@DumitruBerteanu
Please join these two ideas, this was submitted while ago here:
https://forums.autodesk.com/t5/advance-steel-ideas/add-dimension-style-controls-in-mt-for-ordinate-a...
Thank you.
acbsdesign
