Different Cages to match up with different Ladder exist options
I've noticed that the only cage that will connect to a ladder is if you use a straight ladder.
if you choose a different exist option for a ladder for example a flared out at the of of the ladder where the exit is, the cage with not adjust to connect properly to the ladder.
Maybe create different cage options to adjust and connect properly to all the different ladder exit options?
Tim
1 Kommentar
markhubrich
Idee einsenden
