Cross bracing spacer plate
Can there be an option in the macro for cross bracing to add a spacer plate? The binding plate connection only works for double angle bracing, not cross bracing. Currently I have to create my own plate and it is very difficult to make sure they are in the correct position and rotation.
Also, would it be possible to have it so the plate dimensions can be manually changed, either by projection or length/width.
5 Comments
haedicu
DumitruBerteanu
Hello. Could you please share with us a picture/small model with the mentioned request ?
eberg770
See attached for an image of what I am asking for. Please let me know if you need any additional information.
DumitruBerteanu
Thank you for the picture, is clear now. We'll take this idea under consideration.
ibdae
PLeas give also the option for double-flipped L-sections, wich are welded or screwed together with different plate as shown in the screenshot below:
The specialty here ist, that the whole construction is welded. For an other option please insert screws.
Thank you
