Please consider making the linear sloped dimension available within the automatic dimensioning of details.
An example of its use would be to show the diagonal dimension of a rectangular plate, from lower left corner to upper right corner. Currently the only dimensions that can be automated are x, y direction distances and we then need to add the diagonal in manually. NB I am aware that the UCS can be used to control the dimension direction, however this would then change all our other dimensions.
Jane
