Autodesk Vault with Advance Steel 2018
On the webside https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/simplecontent/content/how-... there is a description how AS (AdvanceSteel) works with VAULT.
Unfortunately it works not with 2018er bundle (AS+AutoCAD).
For this, it is necessary to install a “normal” version of AutoCAD as a test-version.
But we need the connection to the VAULT.
My proposal or wish is to have a VAULT-connection for models of AS.
Not for the tables and workshop drawings.
We want to save the models in the VAULT!
To realize this it will be necessary to change the path for the attached folder of the model. The attached folder should be saved on the file-server.
It ist not necessary to manage the revisions with the VAULT.
The reason is to ensure the data security and to have all constructions – from Inventor, AutoCAD, ACAD-Mechanical, etc. – in the VAULT.
2 Comments
Hi @IT-BaH,
we need it as well.
Do you have any new experience, how and if it works between Advance Steel and Vault?
Many thanks in advance
IT-BaH
Hello Karel Grygar,
we need it, it can be installed, but it doesn't realy work.
The problem are the files which are produced by AS.
We make for each part one drawing. So we have hundreds of part-drawings and this is to much to be checked in into VAULT.
The other reason ist, that not all files produced by AS checked in in a workflow. So we are not able to control the checking in procedure.
Have you any experience?
