Show only
Search instead for
Every Isometric view is created by the ucs. So an automatic Isometric view is not possible, you could add it to your drawing style,but then every drawing you create, maybe with processes will use the same UCS. So yes it is possible to add a Isometric view to a drawing style but the result is not what you want. Regards Sebastian
this is possible for all the Advance Steel versions i know - back to 2009. I'm sure your supporting reseller can explain the workflow. There are also some youtube videos out about drawing style customization. A good start are this one and this one.
