Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
WT fitted as stiffener plate
1 REPLY 1
cristianUL24T
115 Views, 1 Reply
Is there a way to cut a WT to make it like a fitted stiffener plateUntitled6.png
1 REPLY 1
Hi @cristianUL24T
On the features tab on the tool palette there is a command called "Element contour rule" this will shape the WT to the W beam and then you should be able to control the offsets and corner cuts etc
Rob Merriman, AEC Technical Lead, Graitec
Technology Administrators
