Hi @cristianUL24T
On the features tab on the tool palette there is a command called "Element contour rule" this will shape the WT to the W beam and then you should be able to control the offsets and corner cuts etc
Rob Merriman, AEC Technical Lead, Graitec
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
