Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Wire Mesh Infill Panel on Guardrails
22 REPLIES 22
Message 1 of 23
5559 Views, 22 Replies
Ok I have a Guardrail system that I need to create a Wire Mesh Infill panel for. The mesh is 4" x 4" x 3/16" pattern with a L 1 x 1 x 1/8" frame all 4 sides. I have the Top and Bottom Chord of the Guardrail established, and have modeled the Angle Framework into the first opening. Any advice on this?
22 REPLIES 22
Message 21 of 23
jcasti1719
I pick a flattened expanded metal as close as I can get to the thickness of wire mesh wanted. Then uncheck use standard hatch and use a custom hatch from the pulldown menu. You may have to change the hatch scale to achieve the required appearance.
Message 22 of 23
in reply to: jcasti1719
Thanks jcasti1719,
Not a bad work around for the moment, although i'll be interested to see what comes up on the material list
Message 23 of 23
95r380disco1
Does anyone know why these options for mesh are not shown in AS2019? Is there any more options in AS2020?
Technology Administrators
