I changes a column and beam size, updated but the changed beams are not on any list. What happened?
Need help
JK
Solved by AleckGiles. Go to Solution.
Did you save the file and run numbering again after the changes?
Did you also make a new BOM Extract - use the Create Lists command again? If you are using Create Lists it makes a static XML file that you need to update manually.
It is normally easier to use the BOM Templates palette. This creates a new temporary extract of the data each time you make a list and only requires 1 click to make a list.
Aleck Giles, Structures Consultant, Graitec
