Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Where's the beam?
4 REPLIES 4
jdk5225g
252 Views, 4 Replies
Where's the beam?
I changes a column and beam size, updated but the changed beams are not on any list. What happened?
Need help
JK
4 REPLIES 4
muleman1
in reply to: jdk5225g
Did you save the file and run numbering again after the changes?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
jdk5225g
in reply to: muleman1
yes, ran numbering
AleckGiles
Did you also make a new BOM Extract - use the Create Lists command again? If you are using Create Lists it makes a static XML file that you need to update manually.
It is normally easier to use the BOM Templates palette. This creates a new temporary extract of the data each time you make a list and only requires 1 click to make a list.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
jdk5225g
in reply to: AleckGiles
yes....working now.
