Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
unfolding length is incorrect - AS2020
2 REPLIES 2
MSE2019
493 Views, 2 Replies
Hi All,
is there anything wrong with the unfolding length in AS2020? I am trying to make a Cylinder of inner diameter 900mm and wall thickness 10mm. the correct unfolded length by calculations should be 2859mm. in AS, I got two different lengths and both are wrong.
if I use Facets per corner=24, the unfolded length comes out as 2819mm and when I use Facets per corner=25, the unfolded length jumps up to 2880mm, is there anyway to get the correct length?
please see the attached screencast
2 REPLIES 2
acbsdesign
in reply to: MSE2019
In MT, Filter 'Expansion',
in General, 'Expansion Method for unfolding' -Pure Median Line.
Screencast
Used the Folded beam command.
When unfolded, the length is 2859mm (9'-4 9/16")
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
MSE2019
in reply to: acbsdesign
Many Thanks
