Hi All,
is there anything wrong with the unfolding length in AS2020? I am trying to make a Cylinder of inner diameter 900mm and wall thickness 10mm. the correct unfolded length by calculations should be 2859mm. in AS, I got two different lengths and both are wrong.
if I use Facets per corner=24, the unfolded length comes out as 2819mm and when I use Facets per corner=25, the unfolded length jumps up to 2880mm, is there anyway to get the correct length?
please see the attached screencast
Solved by acbsdesign. Go to Solution.
In MT, Filter 'Expansion',
in General, 'Expansion Method for unfolding' -Pure Median Line.
Used the Folded beam command.
When unfolded, the length is 2859mm (9'-4 9/16")
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
