Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Trim a beam against a surface
8 REPLIES 8
Message 1 of 9
zirudezirude
412 Views, 8 Replies
Hi Guys,
is there any simple way to trim a column or a beam against a polyline or a surface
8 REPLIES 8
Message 2 of 9
muleman1
in reply to: zirudezirude
what process did you use to cut the beam in the image?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 3 of 9
  • a closed polyline could be used:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 4 of 9
zirudezirude
in reply to: muleman1
Thanks for replying so
That's just 3d object not AS member
Message 5 of 9
Thanks @Sebastian_Eiche to get back to me,
What kind of polyline did you use? a 3D polyline?
is that green line on the screenshot ?
Message 6 of 9
Also did you change the UCS position? it did not work for me
Would you please explain more?
Message 7 of 9
mick-CNF
If this information solves your problem please accept as a solution.
Message 8 of 9
mick-CNF
Message 9 of 9
zirudezirude
Thanks @mick-CNF
