Hi Guys,
is there any simple way to trim a column or a beam against a polyline or a surface
Solved by mick-CNF. Go to Solution.
Solved by Sebastian_Eiche. Go to Solution.
what process did you use to cut the beam in the image?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thanks @Sebastian_Eiche to get back to me,
What kind of polyline did you use? a 3D polyline?
is that green line on the screenshot ?
Also did you change the UCS position? it did not work for me
Would you please explain more?
