Trim a beam against a surface
zirudezirude
zirudezirude
Hi Guys,
is there any simple way to trim a column or a beam against a polyline or a surface
Replies (8)
muleman1
what process did you use to cut the beam in the image?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Sebastian_Eiche
  • a closed polyline could be used:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
zirudezirude
Thanks for replying so
That's just 3d object not AS member
zirudezirude
Thanks @Sebastian_Eiche to get back to me,
What kind of polyline did you use? a 3D polyline?
is that green line on the screenshot ?
zirudezirude
Also did you change the UCS position? it did not work for me
Would you please explain more?
mick-CNF
If this information solves your problem please accept as a solution.
mick-CNF
zirudezirude
Thanks @mick-CNF
