Dear Expert,
I have required Assembly mark with quantity (as per image) in assembly drawing.
I tried. But, not get result. Please to be guided.
@S.MANICKAVASAGAM Please open the drawing style you are using for detailing of assemebly than go to tiltle and fill the token#Height(4.70)%Quantity ~ %ItemNumber ~ %MainPartPosNum#Newline#Height(2.80)#Bold(0)#Underline(0)(%Quantity @ E1)(%Coating)
@Anonymous Please see link below the list of tokens . Tokens are used to pullout the data into drawings. Click on attached link for tokens http://help.autodesk.com/view/ADSTPR/2018/ENU/?guid=GUID-8831F91F-4AFE-489C-8DCD-CDED8DD64DD1
Dear Expert,
Template is call off.
ie, How many assembly quantity in model with assembly position number, some text.
Ex. 3 Nos. REQUIRED TIE BEAM MKD. 2TB1
Here, 3 - Assembly quantity in entire model
2TB1 - Assembly position number
TIE BEAM - Given in member user attribute / any one.
Nos. REQUIRED, MKD - Simple text.
Hi @ArjunGaba,
can i use these Tokens for my Drawing Number - e.g. in processes, in the title block?
@S.MANICKAVASAGAM Use "%Quantity No.s REQUIRED %USERATTR1 MKD. %MainPartPosNum"
PUT IT INTO TITLE BOX You can know more token from below link https://www.graitec.com/faq-item/faq-2455-which-are-the-available-tokens-in-the-pag/
Yes See attached link https://www.graitec.com/faq-item/faq-2455-which-are-the-available-tokens-in-the-pag/ it will explain you better
In the Procesmanager, I have 6 Tokens for my Drawing No. creation only (see attachement). Can I use here also the another Tokens (e.g. for page header)?
