Template
S.MANICKAVASAGAM
Template
S.MANICKAVASAGAM
Dear Expert,
                I have required Assembly mark with quantity (as per image) in assembly drawing.
            I tried. But, not get result. Please to be guided.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Replies (10)
ArjunGaba
@S.MANICKAVASAGAM Please open the drawing style you are using for detailing of assemebly than go to tiltle and fill the token#Height(4.70)%Quantity ~ %ItemNumber ~ %MainPartPosNum#Newline#Height(2.80)#Bold(0)#Underline(0)(%Quantity @ E1)(%Coating)
Hi @ArjunGaba,
can you explain me your token - assembly?
Many thanks in advance
ArjunGaba
@Anonymous  Please see link below the list of tokens . Tokens are used to pullout the data into drawings. Click on attached link for tokens http://help.autodesk.com/view/ADSTPR/2018/ENU/?guid=GUID-8831F91F-4AFE-489C-8DCD-CDED8DD64DD1
ArjunGaba
@Anonymous  for Quantity i.e %Quantity is used
S.MANICKAVASAGAM
Dear Expert,
                       Template is call off.
                    ie, How many assembly quantity in model with assembly position number, some text.
                    Ex.   3 Nos. REQUIRED TIE BEAM MKD. 2TB1
                    Here,  3 -  Assembly quantity in entire model
                              2TB1 - Assembly position number
                              TIE BEAM - Given in member user attribute / any one.
                              Nos. REQUIRED, MKD - Simple text.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
Hi @ArjunGaba,
can i use these Tokens for my Drawing Number  - e.g. in processes, in the title block?
ArjunGaba
@S.MANICKAVASAGAM  Use "%Quantity No.s REQUIRED %USERATTR1 MKD. %MainPartPosNum"
PUT IT INTO TITLE BOX  You can know more token from below link https://www.graitec.com/faq-item/faq-2455-which-are-the-available-tokens-in-the-pag/
ArjunGaba
Yes See attached link https://www.graitec.com/faq-item/faq-2455-which-are-the-available-tokens-in-the-pag/  it will explain you better
In the Procesmanager, I have 6 Tokens for my Drawing No. creation only (see attachement). Can I use here also the another Tokens (e.g.  for page header)?
ArjunGaba
@Anonymous  This location is for Drawing file name . Be careful using it
