Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Tank roof
3 REPLIES 3
s139902
299 Views, 3 Replies
Tank roof
Hi guys,
Please, can you tell me what is the easiest way to make tank roof like on the pictures below ?
I spend last two days to figure it out but wint no result.
3 REPLIES 3
s139902
in reply to: s139902
one more picture
acbsdesign
First and most important will be the length of the outer edge rolled angle.
This will give you the number of Polar Array segments.
Splicing is important because you may need to split the angle and bolts will remain passing through other angle, it will slow you down.
Do one typical segment with 100% independent bolts/members between, and use polar array.
I see you did all the sloping beams first, do one or 3 with the rolled angle and use the polar array.
Regards
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
AleckGiles
HI,
The overall shape is a little similar to the Hopper I modelled in this video Youtube - Advance Steel Hopper.
As you can see it is quite old and the interface has changed a fair bit since but the commands and process are the same.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
