I have a rack I am trying to stretch/extend all 54 angles 1/8" in one direction at once. Any ideas?
Solved by muleman1. Go to Solution.
I tried many ways to multiple stretch with no avail. Even drew a huge plate thinking I could extend or use as a cut to object, but AS would not recognize the plate as an object ??? as a 'cut to' object ...... finally after wasting a couple hours on Google, selected all the angles, then 'shift selected' each system line end grip and was able to stretch all 54 at once.......this is easy and intuitive ????
I would suggest where you can keep items "connected" and they will extend with the moved item.
Extend Items | Advance Steel | Autodesk Knowledge Network
@danielrmc1726 the screencast we attched is the way we did it. There is most likely a better way and we hope to learn it... https://autode.sk/3BPLMJT
You were on the right track with your plate idea. But you need to draw a beam with the system line where you want the beams stretched to. Then you can use the Advance Trim/Extend to that dummy beam. The good news is that you only need a single dummy beam for all the items to be trimmed/extended.
@Jonathan.Jasinski I have wasted countless hours in the past trying to get the "Advance Trim/Extend to the dummy beam". At your lesuire, would you be kind enough to post a screencast of how to accomplish that
System Line Trim | Advance Steel | Autodesk Knowledge Network
Trim and extend to system line and to line
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
In Advance Tool Pallet go to 'Features'
Use shorten at UCS. This will also stretch multiple beams to your UCS.
I've just used this workaround to stretch +100 purlins.
