Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Stretching Multiple profiles
12 REPLIES 12
Message 1 of 13
muleman1
1552 Views, 12 Replies
muleman1
I have a rack I am trying to stretch/extend all 54 angles 1/8" in one direction at once. Any ideas?
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
12 REPLIES 12
Message 2 of 13
in reply to: muleman1
hi,
just good old autocad stretch?
de select a few profiles and it shood work.
in AS if you have made an shortening at beam end, you can move all shortenings at once.
hi,
Message 3 of 13
muleman1
muleman1
I tried many ways to multiple stretch with no avail. Even drew a huge plate thinking I could extend or use as a cut to object, but AS would not recognize the plate as an object ??? as a 'cut to' object ...... finally after wasting a couple hours on Google, selected all the angles, then 'shift selected' each system line end grip and was able to stretch all 54 at once.......this is easy and intuitive ????
Message 4 of 13
danielrmc1726
danielrmc1726
hello i've tried to do what you say here but no luck, could you please do a video of the process?
Message 5 of 13
mick-CNF
in reply to: danielrmc1726
mick-CNF
I would suggest where you can keep items "connected" and they will extend with the moved item.
Extend Items | Advance Steel | Autodesk Knowledge Network
If this information solves your problem please accept as a solution.
Message 6 of 13
muleman1
muleman1
@danielrmc1726  the screencast we attched is the way we did it. There is most likely a better way and we hope to learn it...  https://autode.sk/3BPLMJT
Message 7 of 13
Jonathan.Jasinski
You were on the right track with your plate idea.  But you need to draw a beam with the system line where you want the beams stretched to.  Then you can use the Advance Trim/Extend to that dummy beam.  The good news is that you only need a single dummy beam for all the items to be trimmed/extended.
Message 8 of 13
muleman1
@Jonathan.Jasinski  I have wasted countless hours in the past trying to get the "Advance Trim/Extend to the dummy beam". At your lesuire, would you be kind enough to post a screencast of how to accomplish that
Message 9 of 13
mick-CNF
mick-CNF
System Line Trim | Advance Steel | Autodesk Knowledge Network
Message 10 of 13
mick-CNF
mick-CNF
Message 11 of 13
acbsdesign
acbsdesign
@muleman1
Trim and extend to system line and to line
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
@muleman1
Message 12 of 13
samZT7EV
samZT7EV
Community Visitor
Community Visitor
In Advance Tool Pallet go to 'Features'
Use shorten at UCS. This will also stretch multiple beams to your UCS.
I've just used this workaround to stretch +100 purlins.
Message 13 of 13
mick-CNF
mick-CNF
This was solved 9 years ago.
