I have just noticed the Start tab has disappeared, I only have the current drawing tab available.
Is there a way to get it back?
I've noticed lately that some AS commands are running really slow too - OS is up to date etc.
Solved by CHRIS_ASDL. Go to Solution.
Solved by múinteoir. Go to Solution.
Check the AutoCAD Options for file tabs as below
Or it could be the Startup variable.
Hi David,
Type STARTMODE in the command line and set it to 1. This should turn it back on.
Hope that helps.
Thanks Jonathan and Chris, a restart of AS seen the Start tab back again, I have checked to make sure the Options for File Tabs was selected so, I will keep an eye on it, thanks again for your help.
