Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Start Tab Disappeared
3 REPLIES 3
3982 Views, 3 Replies
I have just noticed the Start tab has disappeared, I only have the current drawing tab available.
Is there a way to get it back?
I've noticed lately that some AS commands are running really slow too - OS is up to date etc.
3 REPLIES 3
múinteoir
múinteoir
Check the AutoCAD Options for file tabs as below
Or it could be the Startup variable.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-t...
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
CHRIS_ASDL
CHRIS_ASDL
Hi David,
Type STARTMODE in the command line and set it to 1. This should turn it back on.
Hope that helps.
Kind Regards
Chris
Hi David,
Hope that helps.
Kind Regards
Chris
in reply to: múinteoir
Thanks Jonathan and Chris, a restart of AS seen the Start tab back again, I have checked to make sure the Options for File Tabs was selected so, I will keep an eye on it, thanks again for your help.
