Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Stair Tread Option in Advance Steel
2 REPLIES 2
701 Views, 2 Replies
Our client specifies for stairs a "Borden Type WB-6 (1 1/4"x3/16") tread with checkered plate nosing, or equal".  Is there an "or equal" in the list of options in the Stair command, or how would I add this?
2 REPLIES 2
Sebastian_Eiche
Borden is not integrated, but you could add a complete new database or you add it to an existing one.
you had to open the management Tools and then the table-editor, open the databases and than have a look in the AstorGratings.
For example Grating_US_Imperial. On the right side you see alle gratings which are included, you could add a row by copy an existing one and use the name you want. After reopen the database in Advance, you could them in the stairs macro.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
in reply to: Sebastian_Eiche
Thanks.  I thought that might be the way to go about it, but wasn't sure.  I've got a little bit of time now, so I'll give it a try.  One of the McNichols gratings looks close to the Borden, so I'll copy that.
Thanks for your suggestion.
