Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
stair step railing
7 REPLIES 7
Message 1 of 8
579 Views, 7 Replies
stair step railing
Hello to everybody.
I started using Advance Steel two weeks ago.
I modelled all structural members of a stairs, exluding steps and railings.  I'd like to know if there is the possibility to automatic model steps and railnigs.
Thank you.
Ing. AT
Tags (3)
Labels (1)
7 REPLIES 7
Message 2 of 8
johnjmbennett
Typical you would use the stair macro and railing macro to achieve the stair flights and railing panels along with some manual modelling,  you should see the icons on the home ribbon, about the middle of the screen.
there are also some additional 3rd party tools/plugins for different type of railings and stairs.
John Bennett
Message 3 of 8
in reply to: johnjmbennett
thank you for the answer. Could you be more specific?
What do you mean with macro?
Where is, exactly, the icon in the ribbon?
Could you give me some links of tool/plugin?
Thank you
Message 4 of 8
johnjmbennett
Stair macros video:
https://youtu.be/tEHNh9RxMw4
John Bennett
Message 5 of 8
@Anonymous
High Turci, unless you make industrial installations, you might consider using Revit too. If you make two mutual referred models, you can benefit from the advantages of both softwares for fast modelling....Succes.
@johnjmbennett
High John, what is a third party plug in for AS you might use regarding stairs?
Kind regards,
Willem.
Message 6 of 8
Hi! I make industrial installations.
Thanks anyway!
Message 7 of 8
johnjmbennett
@Anonymous  ,
The additional tools for stairs and railings in this plugin:
Stairs & Railings
John Bennett
Message 8 of 8
Ok, looks great.
Thank you.
Willem
