Hi, how can I shape the edge of the stiffener?
If the stiffeners are created from a macro in the connection vault.......you can't.
If you really need them to be "shaped"........you will have to delete the joint box and do it manually.......but remember......you will get a slightly messy single part detail if you have a chamfer on the corners of the stiffeners for the root radius.
