Is "Model Role" just another filter?
==> Model Role is a (parameter/atribute/characteristic/property) you input in your element member
Why use "groups" when we have "lot/phase"?
==> Groups are elements with properties in comon
Attributes are used for what?
==> Some projects need properties that are not native ou default in Advance Steel, for example: in progress / in manufacturing...
Are Groups and queries just 2 ways to do the same thing?
==> Query is a way to search some element in your Model Space. You make a query to seache "22 mm bolts"
Using these functions seem to be easy, I am not seeing the difference between them.
==> Yes they are easy to use. Just search and know their functions
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
