Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Scipt Error when Numbering
7 REPLIES 7
Message 1 of 8
Adrian.Mangan
546 Views, 7 Replies
Hi everyone
getting this Script Error when running Numbering, any help appreciated
7 REPLIES 7
Message 2 of 8
CHRIS_ASDL
in reply to: Adrian.Mangan
Hi Adrian,
Looks like you need to do a repair of the software.
https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Kind Regards
Chris
Kind Regards
Chris
Message 3 of 8
múinteoir
Hi Mate,
See below
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Message 4 of 8
wow I'm back to a 1 rating, haha.
No luck with that guys, repaired, and rebooted getting the same thing again
Message 5 of 8
Adrian.Mangan
in reply to: múinteoir
thanks Jonathan
unfortunately no luck repaired and rebooted
Message 6 of 8
Adrian.Mangan
in reply to: CHRIS_ASDL
thank Chris, no luck, hope I don't need to re install just uninstalled 2017
Message 7 of 8
try to use the the reinstall opportunity, this should help, the databases should be not replaced in this option.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 8 of 8
Thank you Sebastian, yea had to re install last night.
All working now.
