Scipt Error when Numbering
Adrian.Mangan
Adrian.Mangan
Hi everyone
getting this Script Error when running Numbering, any help appreciated
Replies (7)
CHRIS_ASDL
Hi Adrian,
Looks like you need to do a repair of the software.
https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Kind Regards
Chris
Kind Regards
Chris
múinteoir
Hi Mate,
See below
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Adrian.Mangan
wow I'm back to a 1 rating, haha.
No luck with that guys, repaired, and rebooted getting the same thing again
Adrian.Mangan
thanks Jonathan
unfortunately no luck repaired and rebooted
Adrian.Mangan
thank Chris, no luck, hope I don't need to re install just uninstalled 2017
Sebastian_Eiche
try to use the the reinstall opportunity, this should help, the databases should be not replaced in this option.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Adrian.Mangan
Thank you Sebastian, yea had to re install last night.
All working now.
