Hi everyone
getting this Script Error when running Numbering, any help appreciated
Solved by Sebastian_Eiche. Go to Solution.
Hi Adrian,
Looks like you need to do a repair of the software.
Kind Regards
Chris
wow I'm back to a 1 rating, haha.
No luck with that guys, repaired, and rebooted getting the same thing again
thank Chris, no luck, hope I don't need to re install just uninstalled 2017
try to use the the reinstall opportunity, this should help, the databases should be not replaced in this option.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Thank you Sebastian, yea had to re install last night.
All working now.
