Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Plates are in inches
8 REPLIES 8
Message 1 of 9
avinash00002002
1193 Views, 8 Replies
avinash00002002
After registering drawing to model all plates dimensions and sizes are coming in inches.  I want it in millimeter.  How to do it.
Can anyone explain me why this occurs.
Avinash
Avinash
8 REPLIES 8
Message 2 of 9
Sebastian_Eiche
open your project settings and have a look for the length units.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Sebastian Eiche
Message 3 of 9
avinash00002002
Yes it is already in mm.
Message 4 of 9
Sebastian_Eiche
we need more informations, do mean the inch sizes in the model or in the detail drawings?
Sebastian Eiche
Sebastian Eiche
Message 5 of 9
avinash00002002
Mdelis in metric unit but problems in detail drawings. All plates dimensions in inches and in the list also.  All beams. Columns and Assembly drawing is in metric.
Message 6 of 9
Sebastian_Eiche
There are a few defaults for the units in drawings in the management tools. And additional you had to use the correct prototypes. Open the prototype and have a look in the project settings and dimstyle
Sebastian Eiche
Sebastian Eiche
Message 7 of 9
janet_black
HiWoman Happy
When creating drawings in Metric the width of the plate is in imperial. To resolve this issue, follow the procedure below.
  1. Select “Management Tools” button in the upper right corner on the Home tab.
  2. Select the Defaults category
  3. Use the filter and type plate
  4. Remove the [20,5006,474] also the “after Width.
Remember to “Load Settings in Advance.”
Go back to the model and Update Defaults.
Please see attachment for a visual step by step
I hope this helps.
Janet
Graitec CANADA
HiWoman Happy
I hope this helps.
Janet
Graitec CANADA
Message 8 of 9
avinash00002002
Now Plate dimensions are in Metric and written scale is changed to imperial.
Message 9 of 9
ashish.rai4997
Observer
Observer
Thanks for the answer
