Hi all,
I'm having a little trouble creating/editing BOM Templates in both structured, and parts lists. I know I have to copy the file I want to edit into the user templates, but for some reason I cannot do that. does anyone have any information on why this would be?
Thanks, Steven
Solved by johnjmbennett. Go to Solution.
Few videos out there ,
also try the knowledge help to give you a starter for topic:
John Bennett
Hi John, I've watched that video, the issue I'm facing is I cannot copy a template to create one i can edit.
So if under the user branch of the bom editor file tree, you cannot select the template, to highlight it and then right mouse button to open the contextual menu to select the copy template option.
John Bennett
I can do that, I can copy it into the user database. But when I go to find the copy it isn't there.
John Bennett
"Maybe check your read write properties of the astoraddin database, this is where the entries are stored in various tables."
This was the issue. Thanks ever so much!
