Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Create BOM Template
6 REPLIES 6
stevenD3ZZG
350 Views, 6 Replies
Create BOM Template
Hi all,
I'm having a little trouble creating/editing BOM Templates in both structured, and parts lists. I know I have to copy the file I want to edit into the user templates, but for some reason I cannot do that. does anyone have any information on why this would be?
6 REPLIES 6
johnjmbennett
in reply to: stevenD3ZZG
Few videos out there ,
https://youtu.be/WI2SJMcbXs4
also try the knowledge help to give you a starter for topic:
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU...
John Bennett
stevenD3ZZG
in reply to: johnjmbennett
Hi John, I've watched that video, the issue I'm facing is I cannot copy a template to create one i can edit.
johnjmbennett
So if under the user branch of the bom editor file tree, you cannot select the template, to highlight it and then right mouse button to open the contextual menu to select the copy template option.
John Bennett
stevenD3ZZG
I can do that, I can copy it into the user database. But when I go to find the copy it isn't there.Bom Editor Copying.png
johnjmbennett
Hmm,
It should work, as typically all copies go into the user part by default path.
Maybe check your read write properties of the astoraddin database, this is where the entries are stored in various tables.
Have you tried a different name convention when copying.
John Bennett
stevenD3ZZG
"Maybe check your read write properties of the astoraddin database, this is where the entries are stored in various tables."
This was the issue. Thanks ever so much!
