Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Numbering
2 REPLIES 2
S.MANICKAVASAGAM
148 Views, 2 Replies
Numbering
Dear expert,
                 In model two assembly with same details.
            I want required different assembly number for both like as B-1 & B-2.
            But, single parts numbers are same.
            Please to be guided.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
2 REPLIES 2
if the parts are the same, AS will set the same number.
Should every Maipart be different or only specific ones?
If every Mainpart should get a new number, you could use the following setting in the numbering dialogue:
If you don't want this, you had to create a difference between these parts and one singlepart had to be different. Therefore you could use a property
For example by using the userattribute1, insert in "a" in one part and "b" in the other and check the box in front of the property. By checking the box, this means: "create difference in numbering by using this item"
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
Dear expert,
          Thanks. Got my requirements.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
