Hi All,
My end goal here is to have:
Is there a way to define how an object gets its number based on the position of its start point?
I am imagining that I would be able to define a rule that says: All beam objects with the model role column get assigned their "%MethodNumber" in order of X-coordinate (ascending) and then by Y-coordinate (ascending).
From what I have read, AS groups all the objects in similar containers prior to assigning its %MethodNumber. It would need to sort the buckets before numbering them, and then sort the buckets somehow?
I see there are numbering settings defined in the table editor, and I see that you can define you own numbering method, but how would you get AS to use a specific numbering method for an object type and model role?
(Management Tools > Table Editor > [Filter]"number")
Steven Payne
The short answer is that you cannot influence the sequence of numbers assigned by AS. It will assign the first number to the item with the highest quantity. The second number to the next highest quantity and so on. Location in the model or any other criteria are not considered and cannot be used.
Aleck Giles, Structures Consultant, Graitec
